Airox Legendair Turbine Box Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Airox Legendair Turbine Box Replacement, How to Properly Clean the Airox Legendair: step 1, image 1 of 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Turbine Box Replacement: step 3, image 1 of 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Turbine Box Replacement: step 4, image 1 of 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Turbine Box Replacement, Turbine Box: step 6, image 1 of 1
    • Make sure to turn off the ventilator before starting the repair.
    • Put the device in a clean and open environment.
    • Thoroughly clean the device before beginning any work.
  5. Airox Legendair Turbine Box Replacement: step 7, image 1 of 1
    • Open the device by removing the five attachment screws (Pl1.20) on the bottom casing side (Pl1-280). Lift off the top outer panel.
    • Carefully separate the two casings to avoid tearing off the keypad connections.
  6. Airox Legendair Turbine Box Replacement: step 8, image 1 of 1
    • Unscrew the three attachment screws (Pl1-130) for the CPU board (Pl1-120).
  7. Airox Legendair Turbine Box Replacement: step 9, image 1 of 1
    • Disconnect all connectors Pl1.J1.CT, Pl1.J2.CT of the turbine control board.
  8. Airox Legendair Turbine Box Replacement: step 10, image 1 of 1
    • Extract the turbine casing (Pl1.50) from its housing and uncouple the flow rate measurement block (Pl1-260), the O2 supply pipes and the piezo solenoid valve.
  9. Airox Legendair Turbine Box Replacement: step 11, image 1 of 1
    • Place the turbine box (Pl1-50) in a clean and open environment
    • Remove the four screws, washers and spacers (Pl1.70, Pl1.80, Pl1.90) in order to successfully extract the turbine control board (Pl1.60).
  10. Airox Legendair Turbine Box Replacement: step 12, image 1 of 1
    • Disconnect the box from the turbine control board (Pl1.J6.CT).
  11. Airox Legendair Turbine Box Replacement: step 13, image 1 of 1
    • Replace the turbine box (Pl1-50).
    • Replace the turbine control board (Pl1.60) on the box with four screws, washers and spacers (Pl1.70, Pl1.80, Pl1.90) (Torque 5 Nm max.).
  12. Airox Legendair Turbine Box Replacement: step 14, image 1 of 2 Airox Legendair Turbine Box Replacement: step 14, image 2 of 2
    • Connect the box to the turbine control board (Pl1.J6.CT).
    • Couple the flow rate measurement block (Pl1-260) to the casing and connect the two O2 supply pipes and the piezo solenoid valve.
    • Then, reinsert the assembly into its housing. Put the cone support (Pl1-50) into place. Put the additional cone support (Pl1-220) also into place.
  13. Airox Legendair Turbine Box Replacement: step 15, image 1 of 1
    • Reconnect all connectors (Pl1.J1.CT, Pl1.J2.CT) to the turbine control board.
  14. Airox Legendair Turbine Box Replacement: step 16, image 1 of 1
    • Reinstall the CPU board (Pl1-120) with the three attachment screws (Pl1-130) (Torque 5 Nm max.)
    • Close the device again, taking all necessary precautions (see Step 2-3)
Perform a final inspection of the device before putting back into service.
Noah Clark
243 Reputation
1 Guide authored
Cal Poly, Team S7-G15, Paton Spring 2020 Member of Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 275
