Airpress LM 50-350 Oil Replacement
  1. Airpress LM 50-350 Oil Replacement, prepare draining oil: step 1, image 1 of 1
    • To ease the draining process, run the compressor for a few minutes and warm up the oil a bit.
    • Make sure to unplug the compressor at this point.
    • Unscrew the filler cap to allow air into the reservoir.
  2. Airpress LM 50-350 Oil Replacement, drain the oil: step 2, image 1 of 2 Airpress LM 50-350 Oil Replacement, drain the oil: step 2, image 2 of 2
    • Using the 5mm hex key, unscrew the drainage plug.
    • With the plug removed, let the reservoir drain until no more oil comes out.
  3. Airpress LM 50-350 Oil Replacement, add oil: step 3, image 1 of 2 Airpress LM 50-350 Oil Replacement, add oil: step 3, image 2 of 2
    • Screw the drainage plug back on.
    • Add the new oil through the filler hole.
    • Make sure the oil level on the indicator is between the lines.
Finish Line
2 other people completed this guide.
knipwim
8,685 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 77
All Time: 851
