Alcatel Go Flip V Flip Phone Camera Replacement
  1. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Screen Cover: step 1, image 1 of 1
    • Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
    • Use caution with a heat gun as you could easily melt the plastic screen cover.
  2. Alcatel Go Flip V Flip Phone Camera Replacement: step 2, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 2, image 2 of 2
    • Insert a curved razor blade under the screen cover to pry it open.
  3. Alcatel Go Flip V Flip Phone Camera Replacement: step 3, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 3, image 2 of 2
    • Use plastic picks to separate the adhesive. Metal is not advised as it will scratch the plastic material the cover is made of. Add more heat as needed.
  4. Alcatel Go Flip V Flip Phone Camera Replacement: step 4, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 4, image 2 of 2
    • Remove the plastic screen cover.
  5. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: step 5, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: step 5, image 2 of 2
    • Remove the four 3.5mm Phillips screws holding the rear cover in place.
  6. Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 1 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 2 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 3 of 3
    • Starting at the hinge side, insert a metal opening tool between the rear cover and the display's frame.
    • Continue down the side of the phone, releasing clips as you go.
  7. Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 1 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 2 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 3 of 3
    • Work your way across the bottom and up the other side.
    • And finally the rear cover is free.
  8. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: step 8, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: step 8, image 2 of 2
    • Using a spudger, disconnect the camera's flex cable.
  9. Alcatel Go Flip V Flip Phone Camera Replacement: step 9, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 9, image 2 of 2
    • Remove the camera from the display.
Jerry Wheeler
60,179 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
178 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 42
