Alcatel Go Flip V Flip Phone Screen Replacement
  1. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Screen Cover: step 1, image 1 of 1
    • Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
    • Use caution with a heat gun as you could easily melt the plastic screen cover.
  2. Alcatel Go Flip V Flip Phone Screen Replacement: step 2, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 2, image 2 of 2
    • Insert a curved razor blade under the screen cover to pry it open.
  3. Alcatel Go Flip V Flip Phone Screen Replacement: step 3, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 3, image 2 of 2
    • Use plastic picks to separate the adhesive. Metal is not advised as it will scratch the plastic material the cover is made of. Add more heat as needed.
  4. Alcatel Go Flip V Flip Phone Screen Replacement: step 4, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 4, image 2 of 2
    • Remove the plastic screen cover.
  5. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Rear Cover: step 5, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Rear Cover: step 5, image 2 of 2
    • Remove the four 3.5mm Phillips screws holding the rear cover in place.
  6. Alcatel Go Flip V Flip Phone Screen Replacement: step 6, image 1 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 6, image 2 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 6, image 3 of 3
    • Starting at the hinge side, insert a metal opening tool between the rear cover and the display's frame.
    • Continue down the side of the phone, releasing clips as you go.
  7. Alcatel Go Flip V Flip Phone Screen Replacement: step 7, image 1 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 7, image 2 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 7, image 3 of 3
    • Work your way across the bottom and up the other side.
    • And finally the rear cover is free.
  8. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Camera: step 8, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Camera: step 8, image 2 of 2
    • Using a spudger, disconnect the camera's flex cable.
  9. Alcatel Go Flip V Flip Phone Screen Replacement: step 9, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 9, image 2 of 2
    • Remove the camera from the display.
  10. Alcatel Go Flip V Flip Phone Screen Replacement, Screen: step 10, image 1 of 3 Alcatel Go Flip V Flip Phone Screen Replacement, Screen: step 10, image 2 of 3 Alcatel Go Flip V Flip Phone Screen Replacement, Screen: step 10, image 3 of 3
    • Unplug the display connector.
  11. Alcatel Go Flip V Flip Phone Screen Replacement, Slice the Adhesive: step 11, image 1 of 1
    • The screen is held onto the display frame with adhesive around the outside edge of the LCD, with a thicker bar of adhesive along the bottom edge as shown.
  12. Alcatel Go Flip V Flip Phone Screen Replacement: step 12, image 1 of 1
    • Heat the edges of the LCD frame to soften the adhesive holding it in place. A hair dryer, heat gun or iOpener will all work fine.
  13. Alcatel Go Flip V Flip Phone Screen Replacement: step 13, image 1 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 13, image 2 of 3 Alcatel Go Flip V Flip Phone Screen Replacement: step 13, image 3 of 3
    • Insert an opening tool between the lip of the frame and the LCD. Use it to slice the adhesive along the top edge.
    • Now go along the side edge.
  14. Alcatel Go Flip V Flip Phone Screen Replacement: step 14, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 14, image 2 of 2
    • Then along the other side.
  15. Alcatel Go Flip V Flip Phone Screen Replacement: step 15, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement: step 15, image 2 of 2
    • Finally, slice the adhesive along the bottom edge. Note that you'll need to go much deeper as there is a wider strip of adhesive along that edge.
  16. Alcatel Go Flip V Flip Phone Screen Replacement, Dismount the Vibrator: step 16, image 1 of 1
    • The vibrator is lightly glued to the display frame. Gently pry it loose, mindful of the wires attaching it to the LCD assembly.
  17. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the LCD Assembly: step 17, image 1 of 2 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the LCD Assembly: step 17, image 2 of 2
    • Lift the LCD assembly from the display frame. There will probably be several strands of adhesive you'll need to separate as you pull it apart.
Jerry Wheeler
60,179 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
178 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 67
All Time: 411
