Alcatel Jitterbug Smart Camera Replacement
  1. Alcatel Jitterbug Smart Camera Replacement, Rear Camera: step 1, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement, Rear Camera: step 1, image 2 of 2
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Camera Replacement: step 2, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 2, image 2 of 2
    • Remove the 13 1 mm Phillips screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Camera Replacement: step 3, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 3, image 2 of 2
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Camera Replacement: step 4, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the Plastic Opening tools to gently dislodge the broken camera from the inside of the phone.
    • Use a tweezers to pull the camera connector from its port.
    • Be careful not to tear the camera from its connection.
Gavin Le
523 Reputation
3 Guides authored
USF Tampa, Team S11-G4, Cheng Spring 2018 Member of USF Tampa, Team S11-G4, Cheng Spring 2018
USFT-CHENG-S18S11G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 316
