Alcatel One Touch Pop 7 Microphone Replacement
  1. Alcatel One Touch Pop 7  Microphone Replacement, Back Cover: step 1, image 1 of 1
    • Begin by opening SD port cover as this is the best location to start prying.
  2. Alcatel One Touch Pop 7  Microphone Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  3. Alcatel One Touch Pop 7  Microphone Replacement, Microphone: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
  4. Alcatel One Touch Pop 7  Microphone Replacement: step 4, image 1 of 1
    • Remove the Microphone from it's slot with the precision tweezers.
  5. Alcatel One Touch Pop 7  Microphone Replacement: step 5, image 1 of 1
    • Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers. For information on how to solder safely and correctly go to this link: How To Solder and Desolder Connections
Philip Schenck
181 Reputation
2 Guides authored
IUPUI, Team S6-G2, Baechle Spring 2018 Member of IUPUI, Team S6-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G2
3 Members
8 Guides authored
One Comment
My tablet Alcatel just went off I don't know the problem I tried charging it,it doesn't even show its charging
Siphamandla Mtiti - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 912
