Introduction
If cleaning the camera lens and adjusting the camera settings does not fix the quality of pictures, you may need to replace the camera inside the Alcatel One Touch Pop 7. This guide will show you how to do so easily.
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
Tool used on this step:Tweezers$4.99
The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
