You're viewing a previously published version of this guide.  View latest version
Older Newer
Alcatel One Touch Pop 7 Volume Button Assembly Replacement
Riley Cooper
Riley Cooper and 3 other contributors
Last updated on May 7, 2024
8 minutes
Easy
Needs Better Images
Introduction
Go to step 1
If your volume and/or power button is not working and you have already cleaned away debris this guide will show you how to replace the assembly to fix the problem.
Tools
  1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement, Volume Button Assembly: step 1, image 1 of 1
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
  2. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 2, image 1 of 3 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 2, image 2 of 3 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 2, image 3 of 3
    Tool used on this step:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
  3. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 3, image 1 of 2 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 3, image 2 of 2
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
  4. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 4, image 1 of 3 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 4, image 2 of 3 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: step 4, image 3 of 3
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
Riley Cooper
926 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,023
