Alcatel Pop 4 Plus Front Camera Replacement
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: step 1, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: step 2, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 2, image 2 of 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: step 3, image 1 of 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: step 4, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 4, image 2 of 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: step 5, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: step 5, image 2 of 2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: step 6, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 6, image 2 of 2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: step 7, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 7, image 2 of 2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: step 8, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 8, image 2 of 2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: step 9, image 1 of 1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: step 10, image 1 of 1
    • Disconnect the camera from the motherboard using the flattened of a spudger.
peter achanccaray
123 Reputation
1 Guide authored
USF Tampa, Team S20-G6, Passmore Spring 2018 Member of USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 447
