Alcatel Pop 4 Plus Rear Camera Replacement
  1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: step 1, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Rear Camera Replacement: step 2, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement: step 2, image 2 of 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Rear Camera Replacement: step 3, image 1 of 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Rear Camera Replacement: step 4, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement: step 4, image 2 of 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Rear Camera Replacement, Rear Camera: step 5, image 1 of 1
    • Use the flat end of the spudger tool to remove the connector.
  6. Alcatel Pop 4 Plus Rear Camera Replacement: step 6, image 1 of 1
    • Pry out the camera with the pointy end of the spudger tool.
Maalik Poleon
202 Reputation
2 Guides authored
USF Tampa, Team S20-G6, Passmore Spring 2018 Member of USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 241
