Alienware 15 R2 Battery Replacement
  1. Alienware 15 R2 Battery Replacement, RAM: step 1, image 1 of 3 Alienware 15 R2 Battery Replacement, RAM: step 1, image 2 of 3 Alienware 15 R2 Battery Replacement, RAM: step 1, image 3 of 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Battery Replacement: step 2, image 1 of 2 Alienware 15 R2 Battery Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 Battery Replacement: step 3, image 1 of 2 Alienware 15 R2 Battery Replacement: step 3, image 2 of 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
  4. Alienware 15 R2 Battery Replacement, Battery: step 4, image 1 of 2 Alienware 15 R2 Battery Replacement, Battery: step 4, image 2 of 2
    • Using a Phillips #0 remove the small 1X 3mm screw behind where the RAM used to be.
    • If you installed additional SSD's, you will need to remove those as well.
  5. Alienware 15 R2 Battery Replacement: step 5, image 1 of 1
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 6X 6mm)
    • Press your finger in the hole next to the hard drive to lift the key board. You may need an iFixit opening tool and work your way around the edges of the keyboard to get it fully lifted.
    • Move slowly as the power cable at the front of the keyboard is still attached to the motherboard as well as the ribbon cables.
  6. Alienware 15 R2 Battery Replacement: step 6, image 1 of 1
    • Remove the ribbon cables on the bottom of the laptop to gain more room in order to lift the keyboard up and out of the way.
    • There is a power cable at the front of the keyboard that you can either remove to lift the keyboard out of the way entirely or keep it attached and rest the keyboard against the monitor face.
  7. Alienware 15 R2 Battery Replacement: step 7, image 1 of 1
    • Disconnect and move aside the left and right wires.
  8. Alienware 15 R2 Battery Replacement: step 8, image 1 of 1
    • Using a Phillips #0 remove the screws holding the battery in. (3X 6mm)
  9. Alienware 15 R2 Battery Replacement: step 9, image 1 of 1
    • Remove the red, white, blue, and black colored speaker wires connected to the motherboard.
  10. Alienware 15 R2 Battery Replacement: step 10, image 1 of 1
    • Lift the battery from the front edge and remove.
    • There are two tabs at the front of the battery on each side that you need to slightly pry open in order to get the battery out. You can pull the speakers out in order to see the tabs better.
5 other people completed this guide.
3 Guide Comments
Honestly made an account to comment on this repair guide, this is extremely incomplete. I’d go as far as saying you’re likely to damage the product by relying solely on this guide, I would turn to a breakdown on YouTube instead. I’m not sure if this is listed under the correct product.
mdumtshali - Reply
The guide is good for someone who has already done repair work on laptops, but it may be difficult to understand for someone who does not have a lot of experience.
Bryan De Gracia - Reply
Made a few modifications like removing the keyboard (and the steps required, this made it so much easier), there were a couple of screws not mentioned for removal, as well as paying attention to the tabs in front of the battery in order to remove it smoothly. Overall, I glad it was available, it at least got me off to a great start. Thanks
Dexter Dionisio - Reply
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 206
All Time: 13,714
