Alienware 15 R2 Hard Drive Replacement
  1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
  2. Alienware 15 R2 Hard Drive Replacement: step 2, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to disconnect the battery cable.
  3. Alienware 15 R2 Hard Drive Replacement: step 3, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 3, image 2 of 2
    • Use the T9 Torx bit to remove the screws on the hard drive cover.
  4. Alienware 15 R2 Hard Drive Replacement: step 4, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 4, image 2 of 2
    • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 33
All Time: 1,927
