Alienware 17 R2 Hard Drive Replacement
  1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Alienware 17 R2 Hard Drive Replacement: step 2, image 1 of 3 Alienware 17 R2 Hard Drive Replacement: step 2, image 2 of 3 Alienware 17 R2 Hard Drive Replacement: step 2, image 3 of 3
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Alienware 17 R2 Hard Drive Replacement: step 3, image 1 of 2 Alienware 17 R2 Hard Drive Replacement: step 3, image 2 of 2
    • Locate the Hard Drive
  4. Alienware 17 R2 Hard Drive Replacement: step 4, image 1 of 1
    • Remove the screws that connect the SSD Bay to the laptop
  5. Alienware 17 R2 Hard Drive Replacement: step 5, image 1 of 1
    • Unscrew the three screws holding the hard drive
  6. Alienware 17 R2 Hard Drive Replacement: step 6, image 1 of 2 Alienware 17 R2 Hard Drive Replacement: step 6, image 2 of 2
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Alienware 17 R2 Hard Drive Replacement: step 7, image 1 of 3 Alienware 17 R2 Hard Drive Replacement: step 7, image 2 of 3 Alienware 17 R2 Hard Drive Replacement: step 7, image 3 of 3
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,791
