Alienware 17 R3 Hard Drive Replacement
  1. Alienware 17 R3 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Hard Drive Replacement: step 2, image 1 of 1
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
  3. Alienware 17 R3 Hard Drive Replacement: step 3, image 1 of 1
    • Pull up and slide the cover off.
  4. Alienware 17 R3 Hard Drive Replacement: step 4, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 4, image 2 of 2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Hard Drive Replacement: step 5, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 5, image 2 of 2
    • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
  6. Alienware 17 R3 Hard Drive Replacement: step 6, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 6, image 2 of 2
    • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
  7. Alienware 17 R3 Hard Drive Replacement: step 7, image 1 of 1
    • Remove the plug from the Hard Drive.
  8. Alienware 17 R3 Hard Drive Replacement: step 8, image 1 of 1
    • Lift the Hard Drive out.
8 other people completed this guide.
Jonathon Tschurwald
869 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 35
All Time: 4,920
