Alienware 17 R3 RAM Replacement
  1. Alienware 17 R3 RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
  2. Alienware 17 R3 RAM Replacement: step 2, image 1 of 1
    • Pull up to slide the cover off.
  3. Alienware 17 R3 RAM Replacement: step 3, image 1 of 2 Alienware 17 R3 RAM Replacement: step 3, image 2 of 2
    • Unplug the black wire with the yellow tag to disconnect the battery from the RAM stick.
  4. Alienware 17 R3 RAM Replacement: step 4, image 1 of 1
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
6 other people completed this guide.
Jonathon Tschurwald
845 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 2,865
