Alienware AW610M Scroll Wheel Replacement
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: step 2, image 1 of 2 Alienware AW610M Scroll Wheel Replacement: step 2, image 2 of 2
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: step 3, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 3, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 3, image 3 of 3
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: step 4, image 1 of 1
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: step 5, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 5, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 5, image 3 of 3
    • Disconnect any wire connections away from the mouse's circuit board.
    • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: step 6, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 6, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 6, image 3 of 3
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: step 7, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 7, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 7, image 3 of 3
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
4 other people completed this guide.
Rana Ashour
241 Reputation
1 Guide authored
3 Guide Comments
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - Reply
Hello, I followed all the steps but I'm left with the two springs that I don't know where to put. I didn't see the two springs in your pictures.
Morar Razvan - Reply
Same, did you find out where it went
ANDREW JOHNSON -
Past 24 Hours: 11
Past 7 Days: 100
Past 30 Days: 552
All Time: 13,644
