Alienware Area-51m Battery Replacement
  1. Alienware Area-51m Battery Replacement, Battery: step 1, image 1 of 3 Alienware Area-51m Battery Replacement, Battery: step 1, image 2 of 3 Alienware Area-51m Battery Replacement, Battery: step 1, image 3 of 3
    • Turn off the laptop and remove all the cables connected to your laptop.
    • Place the back of the laptop up.
    • Remove the six 8mm screws from the back cover using a Phillips #0 screwdriver.
  2. Alienware Area-51m Battery Replacement: step 2, image 1 of 3 Alienware Area-51m Battery Replacement: step 2, image 2 of 3 Alienware Area-51m Battery Replacement: step 2, image 3 of 3
    • Remove the battery cable from the motherboard.
    • Remove the six 5 mm screws holding down the battery using a Phillips #0 screwdriver.
    • Insert translation here
  3. Alienware Area-51m Battery Replacement: step 3, image 1 of 2 Alienware Area-51m Battery Replacement: step 3, image 2 of 2
    • Lift the battery out of the case.
  4. Alienware Area-51m Battery Replacement: step 4, image 1 of 3 Alienware Area-51m Battery Replacement: step 4, image 2 of 3 Alienware Area-51m Battery Replacement: step 4, image 3 of 3
    • Put the new battery back and connect the battery cable to the motherboard.
    • Replace the six 5mm screws using a Phillips #0 screwdriver.
When reassembling your device, follow the instructions in reverse order.
Special thanks to these translators:
zh en
100%
Austin Blakely is helping us fix the world! Want to contribute?
Start translating ›
yupeng ge
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 39
All Time: 2,247
