Alienware M11xR2 Battery Pack Replacement
  1. Alienware M11xR2 Battery Pack Replacement, Removing the Base Cover: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Battery Pack Replacement, Loosen the Screws: step 2, image 1 of 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Battery Pack Replacement, Lifting the Base Cover: step 3, image 1 of 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Battery Pack Replacement, Replacing the Base Cover: step 4, image 1 of 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Battery Pack Replacement, Securing the Screws: step 5, image 1 of 1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Battery Pack Replacement, Removing Screws: step 6, image 1 of 1
    • Remove the two screws that secure the battery pack to the computer base.
  7. Alienware M11xR2 Battery Pack Replacement, Disconnecting cable: step 7, image 1 of 1
    • Disconnect the battery pack cable from the connector on the system board.
  8. Alienware M11xR2 Battery Pack Replacement, Lifting Battery Pack: step 8, image 1 of 1
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Alienware M11xR2 Battery Pack Replacement, Placing New Battery Pack: step 9, image 1 of 1
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Alienware M11xR2 Battery Pack Replacement, Routing Battery Pack: step 10, image 1 of 1
    • Route the battery pack cable in the routing guide
  11. Alienware M11xR2 Battery Pack Replacement, Connnecting Battery Pack: step 11, image 1 of 1
    • Connect the battery pack cable to the connector on the system board.
Finish Line
3 other people completed this guide.
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
1,998 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 27
All Time: 491
