Alienware M14x R2 Wi-Fi Card Replacement
  1. Alienware M14x R2 Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14x R2 Wi-Fi Card Replacement: step 2, image 1 of 3 Alienware M14x R2 Wi-Fi Card Replacement: step 2, image 2 of 3 Alienware M14x R2 Wi-Fi Card Replacement: step 2, image 3 of 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14x R2 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14x R2 Wi-Fi Card Replacement: step 4, image 1 of 3 Alienware M14x R2 Wi-Fi Card Replacement: step 4, image 2 of 3 Alienware M14x R2 Wi-Fi Card Replacement: step 4, image 3 of 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: step 5, image 1 of 3 Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: step 5, image 2 of 3 Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: step 5, image 3 of 3
    • Locate the wi-fi card underneath the battery and unscrew the 3.175 mm size 1 screw.
    • Lift the wi-fi card up and away from the laptop for easier access and handling of the wi-fi card.
  6. Alienware M14x R2 Wi-Fi Card Replacement: step 6, image 1 of 2 Alienware M14x R2 Wi-Fi Card Replacement: step 6, image 2 of 2
    • Lift the gold connectors at the end of each wire up and away from the wi-fi card to detach both antennas, which are the black and white cables, from the wi-fi card.
    • Set aside the now free wi-fi card.
4 other people completed this guide.
angel ventura
177 Reputation
1 Guide authored
Cal Poly, Team 13-4, Forte Fall 2013 Member of Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Members
6 Guides authored
One Comment
Fantastic.
I have replaced many things in my Alienware M14x, but am now purchasing a wireless AC/Blutooth adapter from Amazon. Your diagram allowed me to check the new card form factor with the original "Killer Network" one that shipped with my laptop in 2011.
Great pictures and great guide!
Rob MacGregor - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 9,736
