Alienware M15x Hard Drive Replacement
  1. Alienware M15x Hard Drive Replacement, Battery: step 1, image 1 of 3 Alienware M15x Hard Drive Replacement, Battery: step 1, image 2 of 3 Alienware M15x Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: step 2, image 1 of 2 Alienware M15x Hard Drive Replacement, Compartment Door: step 2, image 2 of 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: step 3, image 1 of 3 Alienware M15x Hard Drive Replacement: step 3, image 2 of 3 Alienware M15x Hard Drive Replacement: step 3, image 3 of 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: step 5, image 1 of 2 Alienware M15x Hard Drive Replacement: step 5, image 2 of 2
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: step 6, image 1 of 2 Alienware M15x Hard Drive Replacement: step 6, image 2 of 2
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: step 7, image 1 of 1
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
David Sann
111 Reputation
1 Guide authored
Cal Poly, Team S11-G3, Banghart Winter 2018 Member of Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 1,072
