Alienware M15x Hard Drive Replacement
  1. Alienware M15x Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x Hard Drive Replacement: step 2, image 1 of 3 Alienware M15x Hard Drive Replacement: step 2, image 2 of 3 Alienware M15x Hard Drive Replacement: step 2, image 3 of 3
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x Hard Drive Replacement: step 3, image 1 of 2 Alienware M15x Hard Drive Replacement: step 3, image 2 of 2
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. Alienware M15x Hard Drive Replacement: step 4, image 1 of 2 Alienware M15x Hard Drive Replacement: step 4, image 2 of 2
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
7 other people completed this guide.
Gabe
8,034 Reputation
3 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,473 Guides authored
1 Guide Comment
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 43
All Time: 33,613
