Alienware M15x RAM Replacement
  1. Alienware M15x RAM Replacement, Battery: step 1, image 1 of 3 Alienware M15x RAM Replacement, Battery: step 1, image 2 of 3 Alienware M15x RAM Replacement, Battery: step 1, image 3 of 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x RAM Replacement, Compartment Door: step 2, image 1 of 2 Alienware M15x RAM Replacement, Compartment Door: step 2, image 2 of 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x RAM Replacement: step 3, image 1 of 3 Alienware M15x RAM Replacement: step 3, image 2 of 3 Alienware M15x RAM Replacement: step 3, image 3 of 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x RAM Replacement, RAM: step 4, image 1 of 1
    • Remove the two indicated screws for the RAM cover.
  5. Alienware M15x RAM Replacement: step 5, image 1 of 1
    • Push the two retaining clips on either side of the ram outwards, allowing the RAM chip to pop up.
  6. Alienware M15x RAM Replacement: step 6, image 1 of 1
    • Pull it straight out of its pocket.
  7. Alienware M15x RAM Replacement: step 7, image 1 of 1
    • Repeat the same process if there are additional RAM chips.
Aria Saberi
121 Reputation
1 Guide authored
Cal Poly, Team S11-G3, Banghart Winter 2018 Member of Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 565
