Alienware M17-R1 CPU Cooler Replacement
  1. Alienware M17-R1 CPU Cooler Replacement, Battery: step 1, image 1 of 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 CPU Cooler Replacement: step 2, image 1 of 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: step 3, image 1 of 1
    • First begin by placing the laptop on a hard flat surface.
    • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
  4. Alienware M17-R1 CPU Cooler Replacement: step 4, image 1 of 1
    • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
  5. Alienware M17-R1 CPU Cooler Replacement: step 5, image 1 of 1
    • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
    • Screws 1 through 4 are integrated into the cooler and will come all the way out.
  6. Alienware M17-R1 CPU Cooler Replacement: step 6, image 1 of 1
    • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
LXA054
337 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 961
