Alienware M17-R1 RAM Replacement
  1. Alienware M17-R1 RAM Replacement, Battery: step 1, image 1 of 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: step 2, image 1 of 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: step 3, image 1 of 1
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: step 4, image 1 of 2 Alienware M17-R1 RAM Replacement: step 4, image 2 of 2
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: step 5, image 1 of 1
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: step 6, image 1 of 2 Alienware M17-R1 RAM Replacement: step 6, image 2 of 2
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: step 7, image 1 of 1
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
LXA054
337 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 805
