Alienware M17-R1 Screen Lock Assembly Replacement
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: step 1, image 1 of 1
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
  2. Alienware M17-R1 Screen Lock Assembly Replacement: step 2, image 1 of 2 Alienware M17-R1 Screen Lock Assembly Replacement: step 2, image 2 of 2
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
  3. Alienware M17-R1 Screen Lock Assembly Replacement: step 3, image 1 of 2 Alienware M17-R1 Screen Lock Assembly Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
  4. Alienware M17-R1 Screen Lock Assembly Replacement: step 4, image 1 of 3 Alienware M17-R1 Screen Lock Assembly Replacement: step 4, image 2 of 3 Alienware M17-R1 Screen Lock Assembly Replacement: step 4, image 3 of 3
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  5. Alienware M17-R1 Screen Lock Assembly Replacement: step 5, image 1 of 2 Alienware M17-R1 Screen Lock Assembly Replacement: step 5, image 2 of 2
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
  6. Alienware M17-R1 Screen Lock Assembly Replacement: step 6, image 1 of 2 Alienware M17-R1 Screen Lock Assembly Replacement: step 6, image 2 of 2
    • If the spring is defective, slide it off the end of the assembly and replace it.
William Davis
323 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 428
