Alienware M17x P01E Center Control Cover Replacement
  1. Alienware M17x P01E Center Control Cover Replacement, Battery: step 1, image 1 of 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Center Control Cover Replacement: step 2, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 2, image 2 of 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Center Control Cover Replacement, Compartment Door: step 3, image 1 of 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Center Control Cover Replacement: step 4, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 4, image 2 of 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 1 of 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 2 of 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 3 of 3
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  6. Alienware M17x P01E Center Control Cover Replacement: step 6, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 6, image 2 of 2
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  7. Alienware M17x P01E Center Control Cover Replacement: step 7, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 7, image 2 of 2
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
Grant Dolmat
328 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 439
