Alienware M17x P01E Cooling Fan Replacement
  1. Alienware M17x P01E Cooling Fan  Replacement, Battery: step 1, image 1 of 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Cooling Fan  Replacement: step 2, image 1 of 2 Alienware M17x P01E Cooling Fan  Replacement: step 2, image 2 of 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Cooling Fan  Replacement, Compartment Door: step 3, image 1 of 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Cooling Fan  Replacement: step 4, image 1 of 2 Alienware M17x P01E Cooling Fan  Replacement: step 4, image 2 of 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: step 5, image 1 of 3 Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: step 5, image 2 of 3 Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: step 5, image 3 of 3
    • Loosen the three black Phillips #1 screws.
    • The screws are held to the fan by a washer and cannot be removed.
  6. Alienware M17x P01E Cooling Fan  Replacement: step 6, image 1 of 2 Alienware M17x P01E Cooling Fan  Replacement: step 6, image 2 of 2
    • Use your hand to gently lift the fan from the laptop.
    • Careful not to pull too hard on CPU fan cable.
Kevin Palacios
169 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 556
