Alienware M17x P01E RAM Replacement
  1. Alienware M17x P01E RAM Replacement, Battery: step 1, image 1 of 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E RAM Replacement: step 2, image 1 of 2 Alienware M17x P01E RAM Replacement: step 2, image 2 of 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E RAM Replacement, Compartment Door: step 3, image 1 of 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E RAM Replacement: step 4, image 1 of 2 Alienware M17x P01E RAM Replacement: step 4, image 2 of 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E RAM Replacement, RAM: step 5, image 1 of 2 Alienware M17x P01E RAM Replacement, RAM: step 5, image 2 of 2
    • Remove the Phillips #1 screw holding the plate.
    • Use your hand to remove the plate.
    • The screw is held to the plate by a washer and cannot be removed.
  6. Alienware M17x P01E RAM Replacement: step 6, image 1 of 2 Alienware M17x P01E RAM Replacement: step 6, image 2 of 2
    • Pull the clips to the side away from each other. The RAM will pop up.
    • Lift forward and gently loosen to pull out of socket.
  7. Alienware M17x P01E RAM Replacement: step 7, image 1 of 1
    • For the second RAM card use the opening tool to gently lift the RAM card forward.
2 other people completed this guide.
Jose
324 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 707
