Alienware P18G M14X R1 RAM Replacement
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: step 1, image 1 of 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 RAM Replacement: step 2, image 1 of 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 RAM Replacement: step 3, image 1 of 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 RAM Replacement, RAM: step 4, image 1 of 1
    • Unscrew the two 6.35 mm using the PH1 screw driver.
  5. Alienware P18G M14X R1 RAM Replacement: step 5, image 1 of 2 Alienware P18G M14X R1 RAM Replacement: step 5, image 2 of 2
    • Lift the plate and remove it to uncover the RAM sticks.
  6. Alienware P18G M14X R1 RAM Replacement: step 6, image 1 of 1
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
  7. Alienware P18G M14X R1 RAM Replacement: step 7, image 1 of 1
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
  8. Alienware P18G M14X R1 RAM Replacement: step 8, image 1 of 1
  9. Alienware P18G M14X R1 RAM Replacement: step 9, image 1 of 1
    • Pull the second ram stick out of its housing.
Andonaq Grozdani
892 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 1,032
