Alienware X51 Fan Replacement
  1. Alienware X51 Fan Replacement, Front Panel: step 1, image 1 of 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Fan Replacement: step 2, image 1 of 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Fan Replacement, Fan: step 3, image 1 of 2 Alienware X51 Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Fan Replacement: step 4, image 1 of 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Fan Replacement: step 5, image 1 of 3 Alienware X51 Fan Replacement: step 5, image 2 of 3 Alienware X51 Fan Replacement: step 5, image 3 of 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 522
