Alienware X51 R2/R3 CPU Replacement
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): step 1, image 1 of 1
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
  2. Alienware X51 R2/R3 CPU Replacement: step 2, image 1 of 1
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
  3. Alienware X51 R2/R3 CPU Replacement: step 3, image 1 of 1
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
  4. Alienware X51 R2/R3 CPU Replacement: step 4, image 1 of 1
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
  5. Alienware X51 R2/R3 CPU Replacement: step 5, image 1 of 1
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
2 other people completed this guide.
rcschwartz709
220 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 2,954
