Alienware m15 R6 Heat-sink Replacement
  1. Alienware m15 R6 Heat-sink Replacement, Base Cover: step 1, image 1 of 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Heat-sink Replacement: step 2, image 1 of 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Heat-sink Replacement: step 3, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Heat-sink Replacement, Removing the solid-state drive in SSD slot one: step 4, image 1 of 2 Alienware m15 R6 Heat-sink Replacement, Removing the solid-state drive in SSD slot one: step 4, image 2 of 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and the system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  5. Alienware m15 R6 Heat-sink Replacement, Procedure to move the screw mount in SSD slot one: step 5, image 1 of 1
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
  6. Alienware m15 R6 Heat-sink Replacement, Removing the solid-state drive in SSD slot two: step 6, image 1 of 2 Alienware m15 R6 Heat-sink Replacement, Removing the solid-state drive in SSD slot two: step 6, image 2 of 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
  7. Alienware m15 R6 Heat-sink Replacement, Procedure to move the screw mount in SSD slot two: step 7, image 1 of 1
  8. Alienware m15 R6 Heat-sink Replacement, I/O board: step 8, image 1 of 1
    • Lift the system board Mylar and open the latch to disconnect the I/O-board cable from the system board.
    • Open the latch to disconnect the I/O-board cable from the I/O board.
    • Remove the screw (M2x4) that secures the I/O board to the palm-rest and keyboard assembly.
    • Loosen the captive screw (M2x2) that secures the I/O board to the palm-rest and keyboard assembly. (skip for NVIDIA GeForce RTX 3050 Ti discrete GPU controller)
    • Lift the I/O board off the palm-rest and keyboard assembly.
  9. Alienware m15 R6 Heat-sink Replacement, Memory module: step 9, image 1 of 1
    • Lift the system board Mylar to access the memory module.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory modulepops up.
    • Remove the memory module from the memory-module slot.
  10. Alienware m15 R6 Heat-sink Replacement, Wireless card: step 10, image 1 of 1
    • Lift the system board Mylar to access the wireless card.
  11. Alienware m15 R6 Heat-sink Replacement: step 11, image 1 of 1
    • Remove the screw (M2x4) that secures the wireless-card bracket to the system board and palm-rest and keyboard assembly.
    • Lift the wireless-card bracket off the wireless card.
    • Disconnect the antenna cables from the wireless card.
    • Slide and remove the wireless card from the wireless-card slot.
  12. Alienware m15 R6 Heat-sink Replacement, Battery: step 12, image 1 of 1
    • Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
    • NOTE: After removing the battery, store the battery cable safely. The replacement battery will not be shipped with thebattery cable. If you want to replace the battery cable, it has to be purchased separately.
    • Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
    • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
    • Lift the battery off the palm-rest and keyboard assembly.
  13. Alienware m15 R6 Heat-sink Replacement, Rear-I/O cover: step 13, image 1 of 1
    • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Disconnect the Tron light cable from the system board.
    • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
    • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
  14. Alienware m15 R6 Heat-sink Replacement, System board: step 14, image 1 of 1
    • The following image indicates the connectors on your system board.
  15. Alienware m15 R6 Heat-sink Replacement: step 15, image 1 of 1
    • Peel the system board Mylar off the system board.
  16. Alienware m15 R6 Heat-sink Replacement: step 16, image 1 of 1
    • Remove the two screws (M2x4) that secure the USB Type-C port bracket to the system board.
    • Remove the USB Type-C port bracket from the system board.
    • Open the latch, and disconnect the display cable from the system board.
    • Disconnect the Alienhead LED cable from the system board.
    • Peel the display cable from the system board.
    • Disconnect the power-adapter port cable from the system board.
    • Peel the power-adapter port cable from the system board.
    • Disconnect the I/O-board cable from the system board.
  17. Alienware m15 R6 Heat-sink Replacement: step 17, image 1 of 1
    • Disconnect the speaker cable from the system board.
    • Open the latch, and disconnect the touchpad cable from the system board.
    • Open the latch, and disconnect the keyboard-controller board-cable from the system board.
    • Open the latch, and disconnect the power-button board cable from the USB board.
    • Open the latch, and disconnect the RGB-IR camera cable from the USB board.
    • Peel the RGB-IR camera cable from the system board.
  18. Alienware m15 R6 Heat-sink Replacement: step 18, image 1 of 1
    • Remove the eight (M2x4) screws that secure the system board to the palm-rest and keyboard assembly. (The USB board and heat sink are attached to the system board.)
    • Lift the system-board assembly off the palm-rest and keyboard assembly. (Before removing the system board, give sufficient time for the heat sink to cool down to avoid injury.)
    • Place the system-board assembly on a clean and flat surface.
  19. Alienware m15 R6 Heat-sink Replacement: step 19, image 1 of 1
    • Turn the system-board assembly over.
    • Remove the USB board.
    • Remove the heat-sink assembly.
  20. Alienware m15 R6 Heat-sink Replacement: step 20, image 1 of 1
    • After performing all the above steps, you are left with the system board.
  21. Alienware m15 R6 Heat-sink Replacement, Heat-sink: step 21, image 1 of 1
    • Remove the six screws (M2x4) that secure the heat-sink assembly to the system board.
    • Lift the heat-sink assembly off the system board.
2 other people completed this guide.
Andrzej
1,672 Reputation
18 Guides authored
2 Comments
Thanks for the guide, it helped me a lot. Do you happen to know the thickness of the thermal pads that go into the Heatsink? It's just that I changed them without seeing the thickness and now my laptop is heating up.
Moisés Martinez - Reply
Nope, done the guide for easier repairs in future, you can easily ask the dell support for that, they answers most of the time quickly
Andrzej -
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 47
All Time: 661
