Alienware m15 R6 Keyboard-controller board Replacement
  1. Alienware m15 R6 Keyboard-controller board Replacement, Base Cover: step 1, image 1 of 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Keyboard-controller board Replacement: step 2, image 1 of 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Keyboard-controller board Replacement: step 3, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Keyboard-controller board Replacement, Battery: step 4, image 1 of 1
    • Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
    • NOTE: After removing the battery, store the battery cable safely. The replacement battery will not be shipped with thebattery cable. If you want to replace the battery cable, it has to be purchased separately.
    • Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
    • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
    • Lift the battery off the palm-rest and keyboard assembly.
  5. Alienware m15 R6 Keyboard-controller board Replacement, Keyboard-controller board: step 5, image 1 of 1
    • Open the latch and disconnect the keyboard-backlight cable from the keyboard-controller board.
    • Open the latch and disconnect the keyboard cable from the keyboard-controller board.
    • Open the latch and disconnect the keyboard-controller board cable from the keyboard-controller board.
    • Remove the screw (M2x2) that secures the keyboard-controller board to the palm-rest and keyboard assembly.
    • Remove the keyboard-controller board off the palm-rest and keyboard assembly.
Andrzej
1,702 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 22
All Time: 473
