AlphaSmart Pro Batteries Replacement
  1. AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 1 of 3 AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 2 of 3 AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 3 of 3
    • Before attempting to remove batteries, make sure the device is turned off.
    • Locate the battery compartment on the back of the AlphaSmart Pro.
    • Push the tab inward and lift up. This will detach the cover from the device.
  2. AlphaSmart Pro Batteries Replacement, Removing The Batteries: step 2, image 1 of 2 AlphaSmart Pro Batteries Replacement, Removing The Batteries: step 2, image 2 of 2
    • Remove each battery by using your fingers or the spudger to pry them from the compartment.
Ashley Orr
130 Reputation
2 Guides authored
Clemson, Team 1-1, Benson Fall 2014 Member of Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 305
