AlphaSmart Pro Front Panel Replacement
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 1 of 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 2 of 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 3 of 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: step 2, image 1 of 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: step 2, image 2 of 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 1 of 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 2 of 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 3 of 3
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
Nathan Smith
22 Reputation
2 Guides authored
Clemson, Team 1-1, Benson Fall 2014 Member of Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 280
