Altec Lansing BoomJacket 2 Disassembly
  1. Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: step 1, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: step 1, image 2 of 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Disassembly: step 2, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly: step 2, image 2 of 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Disassembly: step 3, image 1 of 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Disassembly: step 4, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Disassembly: step 5, image 1 of 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Disassembly: step 6, image 1 of 1
    • Gently pull apart the front panel from the base of the speaker.
3 other people completed this guide.
Zach Braaten
537 Reputation
4 Guides authored
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,566
