Altec Lansing BoomJacket Battery Replacement
  1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: step 1, image 1 of 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Battery  Replacement: step 2, image 1 of 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Battery  Replacement: step 3, image 1 of 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Battery  Replacement: step 4, image 1 of 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Battery  Replacement: step 5, image 1 of 2 Altec Lansing BoomJacket Battery  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Battery  Replacement: step 6, image 1 of 1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Battery  Replacement: step 7, image 1 of 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Battery  Replacement, Battery: step 8, image 1 of 1
    • The battery will be sitting right behind the speakers when the case is open.
  9. Altec Lansing BoomJacket Battery  Replacement: step 9, image 1 of 1
    • Unplug and disconnect the battery from the motherboard.
5 other people completed this guide.
6 Guide Comments
Where can you buy a replacement battery?
Darrell riley - Reply
Where can you buy the battery please?
Juan Roa - Reply
Where can I find ghe batteries? What type of battery ?
Violet Roach - Reply
where ca i buy a replacement battery
Shelley Franck - Reply
This tutorial is incomplete.
Ivan Rodriguez - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 55
All Time: 15,657
