Altec Lansing Mini Lifejacket 2 Back Panel Replacement
  1. Altec Lansing Mini Lifejacket 2 Back Panel Replacement, Back Panel: step 1, image 1 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement, Back Panel: step 1, image 3 of 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 2, image 1 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 2, image 2 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 2, image 3 of 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 3, image 1 of 2 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 3, image 2 of 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 4, image 1 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 4, image 2 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 4, image 3 of 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 5, image 1 of 2 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 5, image 2 of 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 6, image 1 of 2 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 7, image 1 of 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 8, image 1 of 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 9, image 1 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 9, image 2 of 3 Altec Lansing Mini Lifejacket 2 Back Panel Replacement: step 9, image 3 of 3
    • To remove the back panel, gently pull out its wire harness.
5 other people completed this guide.
Stephen Albrecht
1,053 Reputation
4 Guides authored
USF Tampa, Team S3-G2, Nance Spring 2018 Member of USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Members
4 Guides authored
10 Guide Comments
What do I replace once I have it apart? Where's the charging port? How do I get another charging port that works?
Ggs - Reply
The charging port and the aux input are mounted to a circuit board enclosed within a small compartment on the back panel. We didn’t open the compartment in this guide because it requires breaking the seal of the compartment’s gasket, which would be unreasonable to replace. We figured it would be easier to replace the whole back panel instead. My advice for finding a new charging port would be to scour eBay or a similar site for a broken Mini Lifejacket and use its entire back panel as the replacement.
Stephen Albrecht -
can you charge it with an ac adapter like through the aux port?
Naomi - Reply
Mine has the ports on the side not the back were do i get this part
Otis Crowley - Reply
on the IMW-477-CG, the front grill covering the speakers did not have to be removed, only the back. This would potentially avoid damage to the speakers.
In my case, the micro-usb connector was separated from the board. Looks like it was surface mount soldered and power cord stress bending the connector up off the board broke it off.
The 477 also does not have connectors like in the pictures. It’s all soldered.
Where can we find a replacement back?
Bill - Reply
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 105
All Time: 17,908
