Altec Lansing VersA Smart Speaker Head Replacement
  1. Altec Lansing VersA Smart Speaker Head Replacement, External Panels: step 1, image 1 of 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Speaker Head Replacement: step 2, image 1 of 2 Altec Lansing VersA Smart Speaker Head Replacement: step 2, image 2 of 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Speaker Head Replacement: step 3, image 1 of 2 Altec Lansing VersA Smart Speaker Head Replacement: step 3, image 2 of 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Speaker Head Replacement: step 4, image 1 of 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: step 5, image 1 of 3 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: step 5, image 2 of 3 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: step 5, image 3 of 3
    • Detach the two wire connections from the motherboard.
    • Remove the speaker bed from the internal cavity of the device.
  6. Altec Lansing VersA Smart Speaker Head Replacement: step 6, image 1 of 2 Altec Lansing VersA Smart Speaker Head Replacement: step 6, image 2 of 2
    • Orient speaker bed so the speaker heads are facing up.
    • Remove the two 14mm screws using the Phillips #1 screwdriver.
  7. Altec Lansing VersA Smart Speaker Head Replacement: step 7, image 1 of 2 Altec Lansing VersA Smart Speaker Head Replacement: step 7, image 2 of 2
    • Separate the two plastic pieces of the speaker bed.
    • Flip the top plastic piece so the speaker heads are face down.
    • Speaker heads may fall out on their own.
    • Remove the two speaker heads.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 512
