Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: step 1, image 1 of 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: step 2, image 1 of 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: step 3, image 1 of 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: step 3, image 2 of 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: step 4, image 1 of 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: step 4, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: step 5, image 1 of 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: step 5, image 2 of 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
Ben Toland
101 Reputation
1 Guide authored
Cal Poly, Team 17-33, Amido Winter 2015 Member of Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 2,490
