Alternative Opening Procedure
  1. Alternative Opening Procedure, Alternative Opening Procedure: step 1, image 1 of 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: step 2, image 1 of 2 Alternative Opening Procedure: step 2, image 2 of 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: step 3, image 1 of 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 other people completed this guide.
Donald Todd
528 Reputation
1 Guide authored
One Comment
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 15,069
