Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement
  1. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: step 1, image 1 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: step 1, image 2 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: step 1, image 3 of 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 2, image 1 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 2, image 2 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 2, image 3 of 3
    • Use a T8 screwdriver to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 3, image 1 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 3, image 2 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 3, image 3 of 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 4, image 1 of 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 5, image 1 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 5, image 2 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 5, image 3 of 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 6, image 1 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 6, image 2 of 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 6, image 3 of 3
    • Remove the ribbon cable from the slot on the speaker board
  7. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: step 7, image 1 of 1
    • Remove the speaker board which contains the analog to digital converter
Cassidy O'Connor
450 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2017 Member of USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,407
