Amazon Echo Dot 2nd Generation Speaker Replacement
  1. Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: step 1, image 1 of 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: step 1, image 2 of 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: step 1, image 3 of 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Speaker Replacement: step 2, image 1 of 3 Amazon Echo Dot 2nd Generation Speaker Replacement: step 2, image 2 of 3 Amazon Echo Dot 2nd Generation Speaker Replacement: step 2, image 3 of 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Amazon Echo Dot 2nd Generation Speaker Replacement: step 3, image 1 of 1
    • Tap the base against the palm of your hand so that the black speaker component comes out
14 other people completed this guide.
Alexis White
505 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2017 Member of USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Members
12 Guides authored
3 Comments
Where can one purchase the replacement speaker component?
ananomaus - Reply
Can you inform us were to get replacement speaker please.
John Stead - Reply
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
Meghan Craig - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 57
All Time: 13,119
