Amazon Echo Dot 3rd Gen Disassembly
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 3 of 3
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 3 of 3
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 3 of 3
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 3 of 3
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 3 of 3
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: step 6, image 1 of 2 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: step 6, image 2 of 2
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
4 other people completed this guide.
Ben Nicholsonb
250 Reputation
1 Guide authored
2 Comments
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - Reply
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 8,724
