Amazon Echo Dot 3rd Generation Motherboard Replacement
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 3 of 3
    • Turn your Echo Dot over so that the barcode is facing upward.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 2, image 1 of 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 2, image 2 of 2
    • Use a spudger to lift the adhesive connecting the device and the cover.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 3, image 1 of 1
    • Remove the four silver 7.2 mm screws using a T6 Torx screwdriver.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 4, image 1 of 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 4, image 2 of 2
    • Lift the casing of the Echo Dot to separate it from the rest of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
Jacquelyn Jones
266 Reputation
1 Guide authored
2 Comments
Where do we get the parts you bi chh
Fcukermother - Reply
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 82
All Time: 1,431
