Amazon Echo Dot 3rd Generation Speaker Replacement
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: step 1, image 1 of 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: step 1, image 2 of 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: step 1, image 3 of 3
    • Turn your Echo Dot over so that the barcode is facing upward.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: step 2, image 1 of 2 Amazon Echo Dot 3rd Generation Speaker Replacement: step 2, image 2 of 2
    • Use a spudger to lift the adhesive connecting the device and the cover.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: step 3, image 1 of 1
    • Remove the four silver 7.2 mm screws using a T6 Torx screwdriver.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: step 4, image 1 of 2 Amazon Echo Dot 3rd Generation Speaker Replacement: step 4, image 2 of 2
    • Lift the casing of the Echo Dot to separate it from the rest of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: step 5, image 1 of 1
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: step 6, image 1 of 3 Amazon Echo Dot 3rd Generation Speaker Replacement: step 6, image 2 of 3 Amazon Echo Dot 3rd Generation Speaker Replacement: step 6, image 3 of 3
    • Use a spudger to pry the speaker out of the device.
4 other people completed this guide.
Elaina Moore
127 Reputation
1 Guide authored
9 Comments
Now where do I get the new speaker?
Philip Terry - Reply
Now WHERE do I get the new speaker?
vinodhkumar chejarla - Reply
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - Reply
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - Reply
This is only if the speaker isn’t actually blown.
GrantersG -
Past 24 Hours: 12
Past 7 Days: 59
Past 30 Days: 266
All Time: 4,083
