Amazon Echo LED/Microphone Board Replacement
  1. Amazon Echo LED/Microphone Board Replacement, Power and Speaker Driver Board: step 1, image 1 of 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo LED/Microphone Board Replacement: step 2, image 1 of 3 Amazon Echo LED/Microphone Board Replacement: step 2, image 2 of 3 Amazon Echo LED/Microphone Board Replacement: step 2, image 3 of 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo LED/Microphone Board Replacement: step 3, image 1 of 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo LED/Microphone Board Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo LED/Microphone Board Replacement: step 5, image 1 of 2 Amazon Echo LED/Microphone Board Replacement: step 5, image 2 of 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo LED/Microphone Board Replacement: step 6, image 1 of 3 Amazon Echo LED/Microphone Board Replacement: step 6, image 2 of 3 Amazon Echo LED/Microphone Board Replacement: step 6, image 3 of 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo LED/Microphone Board Replacement, Motherboard: step 7, image 1 of 2 Amazon Echo LED/Microphone Board Replacement, Motherboard: step 7, image 2 of 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo LED/Microphone Board Replacement: step 8, image 1 of 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo LED/Microphone Board Replacement: step 9, image 1 of 2 Amazon Echo LED/Microphone Board Replacement: step 9, image 2 of 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo LED/Microphone Board Replacement: step 10, image 1 of 3 Amazon Echo LED/Microphone Board Replacement: step 10, image 2 of 3 Amazon Echo LED/Microphone Board Replacement: step 10, image 3 of 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo LED/Microphone Board Replacement: step 11, image 1 of 1
    • Lift the motherboard up from the Echo.
  12. Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: step 12, image 1 of 2 Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: step 12, image 2 of 2
    • Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
  13. Amazon Echo LED/Microphone Board Replacement: step 13, image 1 of 2 Amazon Echo LED/Microphone Board Replacement: step 13, image 2 of 2
    • Unclip and remove the top volume ring assembly from the Echo.
  14. Amazon Echo LED/Microphone Board Replacement: step 14, image 1 of 2 Amazon Echo LED/Microphone Board Replacement: step 14, image 2 of 2
    • Unscrew the four 9.7 mm T9 torx screws from the bottom of the volume ring assembly.
  15. Amazon Echo LED/Microphone Board Replacement: step 15, image 1 of 1
    • Turn the assembly over and lift up the plate with the buttons.
  16. Amazon Echo LED/Microphone Board Replacement: step 16, image 1 of 2 Amazon Echo LED/Microphone Board Replacement: step 16, image 2 of 2
    • Turn the plate over, then lift and remove black gear and the white plastic ring.
  17. Amazon Echo LED/Microphone Board Replacement: step 17, image 1 of 3 Amazon Echo LED/Microphone Board Replacement: step 17, image 2 of 3 Amazon Echo LED/Microphone Board Replacement: step 17, image 3 of 3
    • Remove the ribbon cable by lifting the brown latch on the ZIF connector.
    • Lift the LED/Microphone board from the plate.
6 other people completed this guide.
Alexander Albert
1,169 Reputation
6 Guides authored
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Members
12 Guides authored
2 Guide Comments
So in Step 15, I’m having a problem reassembling the Plate with buttons back into the volume ring… can someone give me any tricks/pointers please?
JaxyB - Reply
Where can i buy this LED/Microphone board for replacement?
Tuan Nguyen - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 80
All Time: 14,961
