Amazon Echo Look Wi-Fi Module Replacement
  1. Amazon Echo Look Wi-Fi Module Replacement, Front Panel: step 1, image 1 of 1
    • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
  2. Amazon Echo Look Wi-Fi Module Replacement: step 2, image 1 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 2, image 2 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 2, image 3 of 3
    • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
  3. Amazon Echo Look Wi-Fi Module Replacement: step 3, image 1 of 1
    • Heat the front panel with an iOpener.
    • It may help to secure the iOpener to the device.
    • Heat the device for 5-10 minutes to loosen the glue.
    • CAUTION: The iOpener and the device may be hot.
  4. Amazon Echo Look Wi-Fi Module Replacement: step 4, image 1 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 4, image 2 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 4, image 3 of 3
    • Lever the Jimmy between the screen and the device until an opening is formed.
    • Insert opening picks to hold the opening as needed.
    • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
    • Step 3 may need to be repeated as Step 4 is time-sensitive.
  5. Amazon Echo Look Wi-Fi Module Replacement: step 5, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement: step 5, image 2 of 2
    • Remove the front panel by levering the spudger at the top of the device.
  6. Amazon Echo Look Wi-Fi Module Replacement, Midframe: step 6, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement, Midframe: step 6, image 2 of 2
    • Remove the screws from the midframe with a Torx T5 screwdriver.
    • Lift up the midframe
    • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
  7. Amazon Echo Look Wi-Fi Module Replacement: step 7, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement: step 7, image 2 of 2
    • Use a spudger to gently lift up the ribbon until it detaches.
  8. Amazon Echo Look Wi-Fi Module Replacement, Wi-Fi Module: step 8, image 1 of 1
    • Use a spudger to pry the Wi-Fi module away from the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 78
