Amazon Echo Motherboard Replacement
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: step 1, image 1 of 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: step 2, image 1 of 3 Amazon Echo Motherboard Replacement: step 2, image 2 of 3 Amazon Echo Motherboard Replacement: step 2, image 3 of 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: step 3, image 1 of 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: step 5, image 1 of 2 Amazon Echo Motherboard Replacement: step 5, image 2 of 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: step 6, image 1 of 3 Amazon Echo Motherboard Replacement: step 6, image 2 of 3 Amazon Echo Motherboard Replacement: step 6, image 3 of 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: step 7, image 1 of 2 Amazon Echo Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: step 8, image 1 of 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: step 9, image 1 of 2 Amazon Echo Motherboard Replacement: step 9, image 2 of 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: step 10, image 1 of 3 Amazon Echo Motherboard Replacement: step 10, image 2 of 3 Amazon Echo Motherboard Replacement: step 10, image 3 of 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: step 11, image 1 of 1
    • Lift the motherboard up from the Echo.
5 other people completed this guide.
Alexander Albert
1,169 Reputation
6 Guides authored
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Members
12 Guides authored
11 Guide Comments
Where can you get the mmotherboard
Glen Seay - Reply
same question. where do i get replacement motherboard?
akn978s - Reply
This is how to remove the motherboard not how to replace it....geez
adairt - Reply
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Reply
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Reply
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 72
All Time: 15,746
