Amazon Echo Show 10 3rd Gen Woofer Replacement
Macy Ormand
Macy Ormand and one other contributor
Last updated on December 29, 2023
45 minutes - 1 hour
Difficult
Introduction
Go to step 1
This guide will walk you through the replacement process for the woofer found within your Amazon Echo Show 10 3rd Gen device. The woofer is responsible for the output of lower frequency sounds and may need replacement if not functioning properly. The malfunctioning of this component can be seen through distorted audio or the complete absence of sound.
Make sure other solutions found within the Amazon Echo Show 10 3rd Gen troubleshooting page (such as unmuting your Echo or toggling 'Do Not Disturb' off) have been attempted before committing to disassembly and replacement.
This replacement guide requires the user to solder components within the device. For more information on how to solder and desolder connections, please refer to the guide linked here.
iFixit earns commission when you buy through these links.
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: step 1, image 1 of 2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: step 1, image 2 of 2
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 2, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 3, image 1 of 2 Amazon Echo Show 10 3rd Gen Woofer Replacement: step 3, image 2 of 2
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 4, image 1 of 1
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 5, image 1 of 1
    • After desoldering the three cables, lift the woofer out of the shell of the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 47
All Time: 198
